Old 07-18-2007, 12:04 PM
If you are working with 3dsmax, I recommend using the OSGExporter that will export the model into Vizards native format. You can find it on our downloads page.
To rotate the wheels are you using the getChild() command on the car model? If so, you need to make sure that the child you are getting is located below any transform that is being applied to the wheel. This will ensure that the rotations applied to the child are in its local coordinate system.
