The LED indicates the what kind of video input the eMagin is getting.
Solid yellow == Mono input
Solid green == Stereo input
Blinking == No input
If your LED is blinking, the eMagin is not getting a video signal. Make sure your video card is sending a signal on the port the eMagin is plugged into and that you have pluged the VGA cable into the innermost VGA input on the eMagin box thing. You can use the outermost VGA output on the eMagin box to pipe the signal to your monitor.
