Thread: hd in Vizard3.0
Old 07-09-2007, 10:46 PM
mjabon mjabon is offline
Originally Posted by farshizzo View Post
Vizard 3.0 uses OpenHaptics 2.0 by default. If you want to use an earlier version of OpenHaptics then simply add the following line of code before you import the hd module:
viz.setOption('hd.version',1)
import hd #Will use OpenHaptics 1.0
Thanks. What does the version 1 lack that version 2 has? Where can I obtain version 2 if I need it?
