Thanks, but unfortunately <lookat> does not help. May be I did not explain the problem well: the object is vertical cylinder like a stick. It is necessary to coincide ends of this stick with points P1 and P2. No problem to coincide the first end with P1 using <translate>. How to coincide the second end with P2 without long iteration procedure?
