Old 06-06-2007, 03:19 PM
The documentation for the setAnimationSpeed command should explain it. When you use the avatar.state command, you are blending the animation into the avatars cycle, which is animation 0. If you were to execute the animation once using the avatar.execute command, then you would have to specify the actual animation number, in this case 2.
