Hi Wren,
Thanks for the detailed description of this error.
A) For moving the error window, you should see a window called 'Error' in the windows bar. Left-click on it and select 'move'. Your cursor gets automatically placed over the error message window and you can now left-click on it and move it.
B) We did some testing and think your error message might be related to the ppt driver and the com port. We could only replicate it on xp systems and with an old version of the vizppt driver. Please make sure your vizppt.dls is the most recent one that comes with the Vizard 2.12 install (vizppt.dls built 10/24/2003).
C) In case Vizard did not overrite the old driver when installing 2.12, rename your Vizard20 directory and install Vizard 2.12 new.
You can then either work with the new installation or switch back to the old one, but move the latest version of the vizppt.dls into the Vizard20/plug-ins folder.
Hope that helps.
Matthias
