Old 04-30-2007, 11:25 AM
Can you post the code? viztask should not automatically loop unless you explicitly insert a loop using either the while or for statement. Either way, you can exit a task by simply executing the return statement:
MyTask():
    yield viztask.waitTime(1)
    return
    print 'hello' #This code will not be executed
