Old 04-26-2007, 08:50 PM
asimbh asimbh is offline
I tried all possible ways but still no luck. As I mentioned earlier I’m getting the image offset but depth is missing and that can only happen if all the objects in the image are rendered in the same plane, i.e. the offset is same.
I could even achieve the offset by just using Vizard with viz.STEREO without any stereo drivers as I’m using ARvision3D HMD with two separate streams coming in. The offset is always there and I can even change it but depth is not there. That is, most probably, all the objects in the image are rendered with similar offset.
In addition, I’ve tried that “Gallery” Demo provided with the Vizard but again the depth is missing. I really have nothing left to check on my side therefore waiting for your valuable suggestions.
