Vizard simply renders the scene in mono. The nVidia stereo drivers will automatically apply an offset to the view every frame, alternating between left and right. Did you enable stereo through the driver control panel? When setup correctly, the scene should appear to flicker between the left and right views. Also, make sure the driver version for you graphics card matches the version of the stereo drivers. That should be it, there is nothing else you will need to do within Vizard (other than starting in viz.FULLSCREEN mode).
