Old 11-17-2003, 03:29 PM
Hi Alex,
I'm not clear on what your problem is. Are you saying that when you translate one object, all of the objects are being translated? You also mentioned that the scale is different, are the objects bigger or smaller? Could you send me your code so that I could compare it between the two different versions here? If you don't want to post your code on the forum you can send it to lashkari@worldviz.com. Thanks.
