The Patriot should return the distance the sensors are from the source in meters.
Not sure what is causing your problem. Perhaps the sensors are out of range of the source; try placing the the sensors within .5 meters of the source. You can also use the Patriot PDI manager software to verify the data output of the Patriot.
