This is fairly easy to do. With Vizard's network support, you can easly setup a connection between two computers and pass strings/objects back and forth. The Vizard30\examples\network\duckwalk.py script in the Vizard install is an example of two computers connecting to eachother and sending their respective viewpoint position and orientation.
If the two computer you want to connect are not on the same LAN, then you must make sure you have configured your "port forwarding" settings on your firewalls.
Paul Elliott
WorldViz LLC
