03-01-2007, 10:13 AM
From farshizzio in http://www.worldviz.com/forum/showth...hlight=frustum
Vizard will not split up meshes and only render the parts that are in view. If even one polygon of a very large mesh is in view, then Vizard will render the entire mesh. So if you have a mesh that takes up a large area, then I suggest you break up the mesh into smaller pieces.
Paul Elliott
WorldViz LLC
