  #17
Old 02-22-2007, 10:45 AM
Here is some code that calculates the difference between two angles based on the method steve described:
import math
euler1 = [90,0,0]
euler2 = [0,0,90]
def ComputeAngleDifference(euler1, euler2):
       q1 = viz.Quat( vizmat.EulerToQuat(euler1) )
       q2 = viz.Quat( vizmat.EulerToQuat(euler2) )
       delta = q1 * q2.inverse()
       return viz.degrees( math.acos( delta.w ) ) * 2.0
print ComputeAngleDifference(euler1,euler2)
I'll updated Vizard's QuatDiff function to use this method in the next release.
