Old 02-05-2007, 09:39 PM
k_iwan k_iwan is offline
Red face some ideas ?!
@ Vizmaster:
Hi, I'm not quite sure what you're trying to achieve... are you trying to put up like an "advertising" within Vizard where the images loop / change with time? 2k x 2k texture is way to huge for this purporse, I don't know what your spec is, but loading a 2k x 2k for something to be displayed for less than 20 sec is a waste of hardware resources (IMHO)
May I suggest another method if you're doing an "Advertising" within vizard where the image changing over time...
[1] Use jahshaka to string all the images together, create a movie file .avi or .mpg where each image will be diaplayed for only say .. 10 sec.
[2] export this video at this res 512 x 384 pixels or lower
[3] Apply this video file onto a quad / poly and loop it.
I hope this helps/gives some ideas.
Regards,
Iwan
Macquarie University
