Old 01-18-2007, 01:51 PM
mspusch mspusch is offline
if you are using a wireless IC3 by Intersense, the default way to connect this with Vizard is:
- install and RUN the IServer application that comes with the Intersense Software (you should have got it on a CD, otherwise contact Intersense to get it)
- in the IServer software, make sure that your InertiaCube(s) is/are recognized correctly
- now put the command 'PORT_INTERSENSE = 0" before the line
IC3number1 = viz.add('intersense.dls')
- if you add more than one wireless IC3, you'll get the second one with
IC3number2 = viz.add('intersense.dls')
so, your script for adding one IC3 will look like this:
PORT_INTERSENSE = 0
