Thanks Farshid - appreciate all your help.
Just one other matter - I got a copy of the Release notes which shows an example of starting from the command line, but it doesn't include the final '0' - I guess the Release Notes should get corrected....
I also noted that after I run winviz in this way in the Command Window (Win2k), I cannot use the close button anymore to close the window! I have to go to the Task Manager to end the process...
