I think I did no make myself clear.
For collideMesh() to work, the model must be a child of viz.WORLD. If you import all your objects in one file, the objects will be children of the larger model/file object. So you would have to break the objects out of the model and set their parents to viz.WORLD. Here is some code showing what I am talking about.
bigModel = viz.add('allmyobjects.wrl')
smallThing = bigModel.getChild('mySubObjectName')
smallThing.parent(viz.WORLD)
smallThing.collideMesh()
You would have to do this for each model you want to be grabable. Allternativly, you could use the code in my last message and have each object be a seperate file.
Paul Elliott
WorldViz LLC
