Old 12-15-2006, 10:08 AM
giancamati giancamati is offline
Cool importing a single WRL with many objects.
Hello everybody,
I have this problem: I have a single wrl scene with many objects. When I use viz.add(...) function I can visualize the scene correctly. Now, the problem is the Vizards see the entire scene as a unique object instead of a set of objects.
This could be a problem when I would grab a single object in the scene. How can I solve this problem? That is importing a complete scene in wrl file and grabbing each element of the scene as a single object.
For example I have a wrl scene with 300 elements. Should I write viz.add(...) for 300 times if I want to load all these object separately?
Thank you very much.
Giancarlo
