Thread: Timer speed
Old 12-08-2006, 12:01 PM
Timers are not multi-threaded, they run in the same thread as the main graphics loop. If your framerate is 60 fps, then your timer cannot go any faster than 60 Hz.
If you have a timer that takes a long time to calculate, then it will stall the entire graphics loop. No other code will be executed until your timer is finished doing its calculations.
