Originally Posted by farshizzo
It seems your graphics card doesn't support the latest version of GLSL. You might try updating your driver if you already haven't. I'll try to make the shader compatible with older drivers as well.
I had the same problem. I'll try upgrading my driver.
Also, I posted here because I was hoping to find a solution that worked under Vizard 2.5 as well. The main project we need it for is 3.0, so it's OK if it doesn't work in 2.5.
