Old 10-15-2003, 04:17 PM
Well, you could export the head as a separate mesh (cmf) file and then create a separate cfg file using the new mesh as the head. If you need to swap the heads dynamically at run-time then I could look into adding a command to do this. Have you tried the first option yet?
