Old 11-09-2006, 04:46 PM
Colin Colin is offline
newbie problem getting vizard to work
I've just resurrected a system using Vizard 2.5 and a V6 HMD. I've set up my nVidia card so that the primary monitor shows the Vizard user interface and, theoretically, the HMD is set up as the secondary screen and shows the virtual world. The problem I'm having is that the HMD shows a nice window with a proper title bar and then nothing but pure white inside the window. When I move the window over to the primary screen, everything (including the motion tracking) looks fine. Also, any other content moved from primary to secondary (and therefore sent through the HMD) looks fine, so it seems not to be a problem with the HMD itself. I've tried using Vizard demos that have worked fine in the past, so I don't think it's my coding. I hope this makes enough sense to get help!
