object number limitations..
I am adding a large number of particles into my world using the command add("<file>.wrl").The world view window fails to open if the particle number cross a certain limit. How do I overcome this problem?
also ,
I belive the computation hardware requires better processing capabilities as I see the framerates going down as the particle numbers increase.
