Old 10-25-2006, 09:13 AM
Chandan Chandan is offline
Unhappy error while setting material properties.
I get the following error while trying to set material attributes like sethardness()
the function is called as follows an example code:
import vizmat
viz.translate(viz.HEAD_POS,0,5,-10)
viz.lookat(0,0,0)
ground = viz.add('ground.wrl')
ground.collideplane()
ball = viz.add('ball.wrl')
ball.collidesphere()
ball.sethardness(0.1)
ball.reset()
ground.reset()
ball.translate(0,10,0)
ball.scale(0.6,0.6,0.6)
viz.phys.enable()
When I try to run this code, I get the following error:
Scaling image 'worlds/yellow.GIF' from (640,400) to (512,512)
File "myproj.py", line 14, in ?
AttributeError: 'VizChild' object has no attribute 'sethardness'
Scaling image 'worlds/blue.GIF' from (640,400) to (512,512)
