Old 10-17-2006, 10:58 AM
I tested out your script with Vizard 2.5 and experienced the same problem you described. I tried it out with Vizard 3.0 and it works fine. The problem is not caused by manipulating the viewpoint, but by adding a new viewpoint to the main window. In your script the workaround would be to replace the following code:
##Create a new viewpoint
objectTracker = viz.add(viz.VIEWPOINT)
##Get and set the main window to the viewpoint
mainWindow = viz.get(viz.MAIN_WINDOW)
mainWindow.viewpoint(objectTracker)
with:
##Get the main viewpoint
objectTracker = viz.get(viz.MAIN_VIEWPOINT)
##Get the main window
