Old 10-17-2006, 03:27 AM
Plymouth Plymouth is offline
Ok, I've used that tutorial with and without the HMD and using the male and female bodies with the default head, villain, and a custom female head. In every instance there are no display problems, no freezes, and the head doesn't slide depending on viewpoint, but all the heads appeared smaller than they should be. I'd say probably about 2/3 of the correct size.
[edit] I've talked to the technicians here and it seems that there might be a problem with how the NVidia drivers are dealing with stereo viewing. I'm going to turn stereo off and see if the problem persists, but I'm not going to be able to do that until tomorrow.
