Thread: script crash
Old 10-09-2003, 01:05 PM
Can you try out the following code. It should just open up a wxWindow and display a spinning red square. If it is still crashing then your guess is as good as mine
from wxPython.wx import *
#IMPORTANT: YOU MUST DO THIS BEFORE RUNNING ANY OTHER CODE
viz.go(viz.EMBEDDED)
class VizFrame(wxFrame):
	def __init__(self, parent):
		wxFrame.__init__(self, parent, -1, "Vizard Embedded Example", size=(800,600),style=wxDEFAULT_FRAME_STYLE | wxNO_FULL_REPAINT_ON_RESIZE)
		window = wxWindow(self,-1)
		#IMPORTANT: YOU MUST SET THE WINDOW BEFORE RUNNING ANY OTHER VIZ COMMANDS
		viz.setwindow(window.GetHandle())
		quad = viz.add(viz.TEXQUAD)
		quad.translate(0,1.6,5)
		quad.color(1,0,0)
		quad.spin(0,1,0,90)
		quad.disable(viz.LIGHTING)
		#IMPORTANT: SETUP A TIMER TO BE CALLED CONTINUOSLY, IN THIS CASE, EVERY 10 MILLISECONDS
		ID_Timer  = wxNewId()
		self.timer = wxTimer(self,ID_Timer)
		self.timer.Start(10)
		EVT_TIMER(self,  ID_Timer, self.OnTimer)
	def OnTimer(self, event):
		#IMPORTANT: YOU MUST MANUALLY UPDATE THE GRAPHICS FRAME
		viz.updateframe()
if __name__ == '__main__':
	app = wxPySimpleApp()
	frame = VizFrame(None)
	frame.Show(True)
	app.MainLoop()
