Old 10-12-2006, 11:51 AM
problem with stereo mode
Hi again,
I'm having a problem getting into stereo mode.
I have two demo's. The first demo runs just fine.
The second demo involves manipulating the camera's location with a game pad. However, whenever I try to use viz.QUAD_BUFFER, I don't get stereo mode.
Here is my code:
##Name     :George D. Lecakes Jr
##Created  : October 11, 2006
##Modified : October 11, 2006
##Descr    : 	This program creates a viewport that centers around
##				the translational properties of an object similar
##				to that of a video game.
##Game Pad Library Information
import sid
viz.go(viz.QUAD_BUFFER)
viz.viewdist(-5)
#Global Variables
##Height from Interest
H = 0
##X from Interest
R = 0
##Z from Interest
I = 0
##Reference Plane
envio = viz.add('coords.obj')
envio.translate(0,-3,0)
#Model of Interest
modelOfInterest = viz.add('templateModel.obj')
##Create a new viewpoint
objectTracker = viz.add(viz.VIEWPOINT)
##Get and set the main window to the viewpoint
mainWindow = viz.get(viz.MAIN_WINDOW)
mainWindow.viewpoint(objectTracker)
##Initialize Elements
##Object Of Interest
interestx = 0
interesty = 0
interestz = 0
modelOfInterest.translate(interestx,interesty,interestz)
##Viewpoint
viewCoordx = 0
viewCoordy = 10
viewCoordz = 20
objectTracker.translate(viewCoordx,viewCoordy,viewCoordz)
#Function Declarations
def georgesTimer(timerNum):
	## Get the translation information of the desired object
	#interest = modelOfInterest.get(viz.POSITION)
	## Get the translation information of the viewpoint
	#viewCoords = objectTracker.get(viz.POSITION)
	## See which gamepad button has been pressed
	global H
	global R
	global I
	global upCheck
	global interestx
	global interesty
	global interestz
	global viewCoordx
	global viewCoordy
	global viewCoordz
	upCheck = 0
	## Up
	if sid.isbuttondown(7):
		diff = viewCoordy - interesty
		##  If view is above interest
		if  diff > 0:
			H = (H + .1)
			viewCoordy = (interesty + H)
		##  If View is below interet
		if diff < 0:
			H = (H + .1)
		## If View is equal to interest
		if diff == 0:
			viewCoordy = 0
			H = (H + .1)
## Down
	if sid.isbuttondown(8):
		if  diff > 0:
			H = (H - .1)
		##  If View is below interest
		if diff < 0:
			H = (H - .1)
			viewCoordy = (interesty - abs(H))
		if diff == 0:
			viewCoordy = 0
			H = (H - .1)
##Forward
	if sid.isbuttondown(3):
		diff = viewCoordx - interestx
		if  diff > 0:
			R = (R + .1)
			viewCoordx = (interestx + R)
		if diff < 0:
			R = (R + .1)
		if diff == 0:
			viewCoordx = 0
			R = (R + .1)
##Backward
	if sid.isbuttondown(2):
		if  diff > 0:
			R = (R - .1)
		if diff < 0:
			R = (R - .1)
			viewCoordx = (interestx - abs(R))
		if diff == 0:
			viewCoordx = 0
			R = (R - .1)
##Left
	if sid.isbuttondown(1):
		diff = viewCoordz - interestz
		if  diff > 0:
			I = (I + .1)
			viewCoordz = (interestz + I)
		if diff < 0:
			I = (I + .1)
		if diff == 0:
			viewCoordz = 0
			I = (I + .1)
##Right
	if sid.isbuttondown(4):
		if  diff > 0:
			I = (I - .1)
		if diff < 0:
			I = (I - .1)
			viewCoordz = (interestz - abs(I))
		if diff == 0:
			viewCoordz = 0
			I = (I - .1)
	objectTracker.lookat(modelOfInterest.get(viz.POSITION))
	print viewCoordx
##CallBack to Functions
viz.callback(viz.TIMER_EVENT, georgesTimer)
viz.starttimer(0,0, viz.PERPETUAL)
