Old 10-11-2006, 12:04 PM
The error means that the object you are trying to access is not a list. This is because viz.get(viz.POSITION) is not a valid command. If you are trying to get the position of the viewpoint try the following instead:
viz.get(viz.HEAD_POS)
For node objects you would do:
node.get(viz.POSITION)
