To run a Vizard script from the command line you need to execute
'Vizard.exe' and pass the file name and "-r" as the arguments. This will basically open up the main Vizard program and immediatley run the specified script. Here's an example:
C:\Program Files\Vizard\bin\Vizard C:\myscript.py -r
One thing to note, if there are spaces in the name of your script path you need to inclose it within quotes:
C:\Program Files\Vizard\bin\Vizard "C:\my script.py" -r
Good Luck!
-- farshid
