Hi Howard,
The latest version of Vizard increased the texture limit, I believe it is 1000. You might want to update to the latest version. If you need more than 1000 textures then you might consider converting them to an AVI or MPEG video file.
Regarding your second question, is your system constantly changing the images while the script is running? Also, are these new images going to replace previous images? If you don't mind, could you explain exactly what you are trying to do, so that I could come up with the best solution. I'd like to mention that Vizard has a dynamic texture plugin, so that might come in handy here.
