Originally Posted by Pastscapian
I meant to ask if the spacial hierarchies means that you can have a bunch of models, which may be 100,000 polygons or more and as long as they're all not being seen at once this is fine.
Yes, that is what I meant.
Does this also mean that it can be used for going from a building exterior to it's interior which is a different model?
I'm not exactly sure what you mean here. Vizard does not perform occlusion culling, which means if you are inside a building it will still draw whatever is on the other side of the wall. However, you can manually switch off the interior geometry when you are outside the building and vice versa.
