Thanks.
Yes, I studied those two programs. now I have two questions.
Question1:
I tried to load a dynamic texture by image swapping, but vizard said I can't load more than 200 images in one script, is that correct? if it is, that means I need to convert image sequences into avi or mpg file as dynamic texture if I want to play back a long time image squences, right?
question2:
In my application, at startup, my script will load some pre-calculated image sequences as texture, meanwhile, my system will get continous images as input, after doing simple works on those images, then tranfer them into vizard to be new textures. is vizard able to do that job?
Thank you very much.
Howard
