Running EXEs on machines w/previous R2 installations
If you attempt to run a R3 published EXE on a machine that has had R2 installed but never R3 installed, then the EXE will not function correctly and will produce a number of errors. R2 unfortunately defined itself in the system path and this collides with R3. The R3 installer removes this entry from the system path.
To remedy this, either install R3 Beta or manually remove "c:\program files\vizard25" from you system's PATH environment variable.
