Thread: 3D sound
Old 09-29-2003, 10:46 AM
ok, I got your sound file working by changing the sample rate from 22 kHz to 48 kHz. I'm not sure why this was a problem, but it seemed to fix it. To change the sample rate open the wav file with the "Sound Recorder" program that comes with Windows. It's usually under Start Menu -> Programs -> Accessories -> Entertainment. When you have the file open click on File -> Properties. Then click on the "Convert Now" button. There will be a list called "Attributes". Scroll to the very bottom and choose 48 kHz. I chose the one with 8 bit Mono just because that's how the original file was. Then click OK and save the file. That should hopefully do it, let me know if it doesn't work.
By the way "Pool King", prepare to be dethroned tonight.
