Old 09-11-2006, 12:24 PM
giuseppe giuseppe is offline
It still...
but probably I did not explain myself correctly.
I created "myroom" script as an example of the "learn the basics" tutorial.
The room I created work correctly when I use the 3D screen. On the other hand, when I run the same script ONLY by using my laptop I do not see the same room clear (in bidimensional space), instead I still see the room with double effect, which is the one required for 3D. Is there any way to navigate within that room without 3D monitor and have a "clear" image of it?
In other word, is Vizard made for creating 3D environment without the possibility of navigating within them in 2D? Can I run the scripts I create with Vizard as I run the 3D videogames in my laptop?
This question is critical for me since I would use this software eventually to administer tests to brain damaged patients and other individuals without using a 3D monitor. If I cannot do so it does not make sense for me to learn how to use it.
Thank you so much for your help.
giuseppe
