Old 09-06-2006, 07:29 PM
Looks good. I just realized that the texblend operation is not the same as the blending in the example website you posted. I've attached another example that uses a shader to perform the correct blending. This example assumes the detail texture is gray scale. Let me know if this is better.
File Type: zip DetailTextureExample.zip (901 Bytes, 3707 views)
