Problem with database import
I am now trying to use the MySQL database with Vizard. I installed the MySQLdb module, which is the Python's interface API to MySQL.
When I run the command "import _mysql", I get the following error: "Module use of python24.dll conflicts with this version of Python".
Also, I run Vizard 2.5.
Note that when I run this command directly from the Python IDLE, it runs fine.
Thanks for your help!
Patrick
