Old 09-01-2006, 11:52 PM
tobin tobin is offline
Publish as EXE - Introduction
Available starting R3 Beta 2
Publishing your simulation as an executable is a new bundled feature that “compiles” your simulation—including all scripts and resource files—into a single .EXE package. The compiled package will work as a fully functional Vizard development environment with the notable difference being that it can run on any machine now without installing Vizard first. There is a restriction, though; “compiled” simulations cannot be edited or modified (i.e., scripts or resource files changed) without recompiling on a licensed Vizard development machine.
Accessing and using this feature is easy as it’s built into the Vizard development environment. Under the file menu, you’ll now find “Publish as EXE…”. A Wizard will walk you through the necessary steps. The compiler has two steps; the first requires that you run your script so that all dependencies (across your project files, Vizard modules, Python, etc) can be identified. Second, it compresses everything together into a single EXE that can be distributed royalty-free.
Other limitations:
  • Published EXEs are unable to generate AVI recordings by the user pressing F12.
  • Published EXEs from Trial/Lite editions will self-exit after 2 minute (Beta 2 can be activated as a full Development edition and so it’s published EXEs will not have this restriction)
  • Published EXEs cannot server as members in a cluster.
