Old 08-29-2006, 09:56 PM
You want to stream the frame buffer uncompressed at 60 hz? What window size are you running in?
Does Vizard store the ID of the OpenGl window it opens?
There is no built-in way to get the OpenGL ID from Vizard.
A plugin could be made to capture the screen contents of the graphics window and return it as a string in python. If you are using Vizard 3.0 then I could create this plugin for you.
BTW, I'm new to Vizard, so where can I report bugs?
You can report bugs on the forum.
