Old 08-22-2006, 06:01 PM
Can't seem to find any code samples for you to get started with the laser pointer interaction. I suggest that you take a look at the algorithm that implements the laser pointer in your previous code base and replcate that in Vizard.
You will probably want to use Vizard's intersect or pick functions. These guys will help you select objects in the world. Look'em up in the help.
