Old 08-10-2006, 10:35 AM
I like the workflow of your second alternative, defining the positions of the control points in the modeling software. You could create a naming convention for the child objects in Blender, get their positions with the <VizNode>.getChild() fucntion in a loop and automaticly generate the paths.
CP_COUNT = 50
CONTROLPOINT_PREFEX = 'control_point'
controlPointList = []
def generateControlPoints():
	for cpNumber in range( CP_COUNT ):
		pointNode = bigMap.getChild( CONTROLPOINT_PREFEX + str( cpNumber ) )
		if pointNode != None:
			cp = viz.addControlPoint()
			cp.translate( pointNode.getPosition() )
			cp.rotatequat( pointNode.getQuat() )
			controlPointList.append( cp )
			print 'Missing control point node: ' + CONTROLPOINT_PREFEX + str( cpNumber )
Does anyone else have a solution to this common task?
Paul Elliott
WorldViz LLC
