Old 08-01-2006, 12:10 AM
k_iwan k_iwan is offline
Mesh Loaded, with wrong texture placement, no animations...
I did export out to binary format and I was able to load into vizard3!!!
The animations are not working. Initially, the texture wasn't loaded, then I exported out again with proper image path, the UV seemed to be messed up. The animations are definitely there. So what I'm thinking is, probably there is a problem with the exporter script. I will have another test with different bone structure... hopefully we can end this chapter nicely
Regards,
Iwan
(...then Iwan hums again.. the battle of the republic....stryper version...)
