Old 09-11-2003, 01:27 PM
david david is offline
Thanks I look forward to next release then.
However, before releasing v 2.11, you may want to try and run simpleworld.py in vizard 1.098 and 2.10. On my computer the former works fine and the latter crashes everything (I have to unplug my machine, but this may have nothing to do with vizard). On other computers, the results look similar but are not exactly the same (position is not the same). Why is that?
And for some more complex VRML files that I have, vizard 2.10 displays them in a way that is so different that I can not even see them. Using the mouse I could retrieve on or two objects but the whole scene was mostly messed up.
David
