Old 07-27-2006, 10:32 AM
tobin tobin is offline
You're right, when adding a PeopleMaker built head using the default methods onto a standard avatar body, Vizard will try to hide the "m_head.cmx" node. cmx is basically the same thing as cmf. If you want the convenience of Vizard's automatic head removal, then you need to rename your head cmf to m_head.cmx.
If you're trying to accomplish something else, can you please send your same script so we can better understand what you're doing?
