Old 09-11-2003, 12:01 PM
david david is offline
Hi, it did it again, although it does not seem to prevent the script from running. Here is the error message:
File "<string>", line 1, in ?
File "settingUpRooms.py", line 42, in ?
positions[i].makeIdent()
File "C:\Program Files\Vizard\vizmat.py", line 181, in makeIdent
transform.makeIdent(self.id)
SystemError: error return without exception set
The portion of the script containing the line was :
positions = []
positions.append(vizmat.Transform())
for i in range(0,11):
If I remove the line incriminated, then I get the same kind of error message when I try to modify the transform objects (set them to rotations for instance)
The strange thing is that if I run that portion on its own, I do not get an error
David
