Hi Kyler, when starting the Vizard script or resetting the InertiaCube2 direction the heading direction of the HMD/IC2 setup must be towards virtual north. If that's not the case, your movement direction will be off by the degree of your initial offset to the virtual north.
Hope that helps! Matthias
