Old 06-30-2006, 03:22 PM
spacefarer spacefarer is offline
3d viewpoint movement
I just tried the script for R2.5 as shown below which was given by Farshid, but it doesn't work with R3. Could anyone tell what's wrong with it, please?
#Add a ground
viz.add('tut_ground.wrl')
#Get main viewpoint object
#Create a variable that will tell whether viewpoing is currently moving/turning
view.animating = 0
#Variable that holds current destination value
final = [0,0,0,0]
def rotateview(x,y,z,angle):
#Make sure view is not animating
if not view.animating:
#Compute rotation of turning body 90 degrees to right
xform = viz.Transform(view.get(viz.BODY_MAT))
xform.preRot(x,y,z,angle)
final[:] = xform.getRot()[:]
#Start animating viewpoint
view.spinmask(viz.BODY_ORI) #Spin the body orientation
view.spinto(final,2,viz.TIME) #Spin for 2 seconds
view.animating = 1
def onkeydown(key):
if key == viz.KEY_UP:
pos = view.get(viz.HEAD_POS)
trans = view.get(viz.BODY_LOOK)
#Round values to nearest integer
final[0] = int(round(pos[0] + trans[0]))
final[1] = int(round(pos[1] + trans[1]))
final[2] = int(round(pos[2] + trans[2]))
view.goto(final,1,viz.TIME)
view.animating = 1
elif key == '6': #yaw right
rotateview(0,1,0,90)
elif key == '4': #yaw left
rotateview(0,1,0,-90)
elif key == '8': #pitch up
rotateview(1,0,0,-90)
elif key == '2': #pitch down
rotateview(1,0,0,90)
elif key == '9': #roll right
rotateview(0,0,1,-90)
elif key == '7': #roll left
rotateview(0,0,1,90)
def onstop(object, type):
if type == viz.MOVE:
#Viewpoint is done moving, translate it to the final value just to be sure
view.translate(final)
view.animating = 0
elif type == viz.SPIN:
#Viewpoint is done spinning, rotate it to the final value just to be sure
view.rotate(final,viz.BODY_ORI)
view.animating = 0
view.callback(viz.STOP_EVENT,onstop)
