Old 06-30-2006, 03:43 AM
giancamati giancamati is offline
flockOfBirds events
Hello everybody,
I found that Vizard is so simple in working with FlockOfBirds trackers. Now I woudl ask you for how can I event mapping generated by the FOB? I followed the example in the manual that manages the FOB to move the head position. I would use it to change a 3D cursor represented by a sphere. Where can I find an example? What is the event releted to the FOB?
I found that I can map viz.TRACKER but I think this is not the right event. Isn't it?
Thank you so much.
Giancarlo
